Thread: Best place to buy Connector Plugs
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Best place to buy Connector Plugs
    I'm after a male and female connector plug for adding the aux in cable for the shelf under the cd70. I'll be adding the cable to the back of the cd70 but don't want to wire directly from the aux in socket to the unit but want to be able to disconnect if need be.
    Any ideas on where I can get a universal type socket from that will cover the three wires needed?
    Hope that makes sense
    Try maplins mate - I got a 3 pin fan plug from a PC there for a few quid which works perfectly...
    Basically, one of these then cut it in the middle, and you have a plug with 3 wires...
    http://www.maplin.co.uk/Module.aspx?ModuleNo=37058
    @home
    Engine : 1.9 CDTi
    PC parts I should have thought of that... probable got something with all my pc junk I've acquired over the years.. cheers
  1. CDC 40 connector
    By unknowngman in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2009, 08:44
  2. What's that connector?
    By Largespanners in forum Bodywork & Interior
    Last Post: 16th July 2009, 08:21
  3. What does this connector do?
    By paulw563 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2008, 00:44
  4. Connector
    By Barry in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 06:58
