Thread: Any idea if they will fit
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Any idea if they will fit
    Hello peps, i have found a set of 20 inch wheels for sale that i am very tempted to buy for my Vectra but the offset and pcd is slightly different. I know that the Vectra is et45 and the pcd is 5x110 but these wheels are et40 and the pcd is 5x108, any ideas if they will fit. They have come off a Jag if that helps. Cheers.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    In theory with wobble bolts you shopuld be ok. However I have asked before about fitting ford/Jag wheels and someone said something about the fact they used flat bolts, but I could never find any more info about this???? Also check the bore, as I seem to remember they are a slightly smaller bore than VX.
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    they will stick out an extra 5 mm than the standard wheels but without knowing how wide they are would be diffucult to say if they would fit! You woud need adapters to take the 108 to 110 which would at the smallest be 15 mm probally so you are looking at an extra 20 mm sticking out as well as how ever much wider the wheels is as its 20" so do some homework first and findout the width and see how wide adapters are and get back to us mate
    Regular Member ballan22direct's Avatar
    isle of lewis
    You should be fine with wobble bolts mate. You shouldn't need hub adapters.
    Jan 2010
    glasgow
    wobble bolts and spigot rings , its the ofset and how wide they are that should be your most concern,spigot rings will help in the bore size and help or hinder the of set plus watch how wide a tyer u get for them
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    dose has put 20inc wheels on his might be worth sending him a pm
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by hoochydady View Post
    Offset is et40, pcd is 5x108, wheels are 9x20 and tyres are 245/35/20.
    Jan 2010
    glasgow
    i have 19 mania with 235/35/19 et 45 and about 8 to 8 1/2 inch wide and there about a finger thickness from the struts, in all honesty u ether going to have to buy them and take ur chance, or ask a alloy wheel supplyer, i have seen merc audi vw and ford alloys on vectras so u may get away with it but there 20s it may hit the strut or rub the wheel arch
  1. anyone got an idea?
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 17:17
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
