Thread: tap and die
    Regular Member denzilbud's Avatar
    cambridge
    Default tap and die
    does anyone know which size tap and die i need to rethread a lambda hole on a z22se(position 2)
    Ashington, Northumberland
    It should be M18 1.5
    cambridge
    cheers mate dint expect an answer that quick 10/10,is it the same size for all sensors
    Yea thats a pretty standard size. There are anomolies though
    cambridge
    ok cheers which other sizes should i have to hand in case its differnt
    There are M12 ones as well but you'll find yours will be M18. You will need a 22mm socket and ratchet or spanner
    cambridge
    ok thanks for your help mate
    NP
