Thread: directions to tenby area from nw england towing ??
    wirral
    Default directions to tenby area from nw england towing ??
    hi all
    want to run a question by u all which way from the wirral towing a caravan would u go to tenby area ?? had a few diff ideas from lads at work but they dont tow
    any help would be great
    thanks
    Oct 2007
    chesterfield,derbyshire,uk
    Well I've done it from Harrogate towing (where I used to live in the past). Obviously the first part is of no interest to you, but the last bit was
    M53 to End onto A55. Left on A483 Wrexham, Oswestry, Welshpool. Keep going on A483 Newton, Llandrindod Wells, Builth Wells. As far as Llandovery, then A40 (Carmarthen) to St Clears join A477 pass Kilgetty then left A478 (Tenby).
    wirral
    thanks 4 your quick reply can u remember how long it would take from the a483 wrexham rd roughly and what the roads where like ? is it very hilly, and decent rds
    Oct 2007
    It is a good few years now, so can't remember how long it took, but probably a good 2 -3 hours maybe. It is all single carriageway pretty much once you get on the A483.
    The A483 and the A5 merge at some points, so as I recall it's pretty good straight road with steady inclines etc, nothing too drastic at least as far as Newtown. The Newtown to Llandrindod Wells is the worst bit, quite twisty and some steep bits in places, so may be worth branching onto the A470 at Newtown and then picking up the A483 at Builth Wells. It's further that way, but is a better road for that section.
    After that it's fine all the way to Tenby
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    AT LEAST 4 hours from Wrexham. If you do Newtown in an hour you are going well.
    I do Swansea in between 2 1/2 and 3/4 hours and that is quick ( not towing). Newtown - Llandrindod Wells is bendy in parts (worst bit is near Newtown - I know a short cut but not for vans)
    Stops for food on route are
    Chirk ( McDonalds )
    Oswestry ( Burger King/Little Chef )
    Newtown ( Morrisons, Tesco, McD's, Chippy )
    Landrindod Wells ( Chippy )
    Builth Wells ( Little Chef/BurgerKing )
    Beyond this I do not know.
    Have you considered The Gower ? Great beaches and countryside with Swansea and The Mumbles nearby and if you like golf well........
    Different route for this, sat nav and AA/RAC directions are pap but don't take my advice, I've only done it about 800 times
  1. PVS map, directions and web site
    By Duncan in forum PVS 2008 - June 8th
    Last Post: 5th March 2008, 23:27
  2. Vec SRi XP - Tenby - 11th April
    By MattB in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 13th April 2007, 22:25
  3. PVS map and directions.
    By Duncan in forum PVS 2007 - 3rd June
    Last Post: 10th January 2007, 12:52
  4. PVS map and directions
  5. tom tom directions
    By ed taylor in forum General Chat
    Last Post: 23rd April 2006, 01:07
