Thread: Water pump? Anyone had similar issues
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Water pump? Anyone had similar issues
    My squealing noise which I thought was the alternator is still ever present but the wife had the car out today and she paniced because it beeped and a 'funny looking symbol' showed up on the display, possibly an 'engine'?!
    Anyway, this was this morning so told her to just leave it and I would go have a look after work.
    The 'engine' symbol was the radiator symbol and it was short a litre of water but is hard to see if it is dripping or leaking due to the splash tray! Anyway, my point is, no oily residue in radiator resevoir, no mayo in oil and no battery light and charging at 14 + v
    Anyone else had a water pump go? Not wanting to be driving the car until it is either fixed or at least diagnosed.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by RobW View Post
    MY Squealing was the belt, a bit of candle fixed this, I changed the water pump at 60,000 when I did the cam belt, it was worn out.
    Regular Member DaveW555's Avatar
    Cannock
    Rob as I've said before if you're in any doubt with these water pumps, change it.
    Tain - Easter Ross
    Quote Originally Posted by DaveW555 View Post
    Well, car is at my Dad's house, going to get it towed through to the garage. Was just through having a closer look, didn't take the engine mount off but there was water on the drive shaft and along the bottom of the engine.
    Taking no chances, timing belt kit and water pump ASAP.
    Jun 2009
    wallsend
    Water pump went at 46000 mile and had to replace the belts, lucky it was under warranty, but the belts weren't, 167 for the belts.
    N.Ireland
    my water pump went on my 05 cdti,was on the way to the garage to get it checked and it all went belly up,valves /rockers had to be replaced,complete nightmare in the end.
    Tain - Easter Ross
    Well, got a pump for £22, pattern but local vx didn't have any until Friday and belt kit for £96 all in. Car has ben RAC'd to the garage and will hopefully get it back before the weekend.
    Alternator arrived today too so at least I have a spare if (when??!) it goes.
    Tain - Easter Ross
    Timing belt and water pump changed and its still a bit squeaky when cold but putting that down to the alternator belt having got wet, will do that next.
    Old water pump was ready for shattering!
    Cannock
    Lucky that you changed it when you did then, really chuffed that it worked out ok for you matey could have disastrous if you'd left it any longer.
  1. water pump
    By GCusdin in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:16
  2. water pump
    By mucky69 in forum Engine & Drivetrain
    Last Post: 10th July 2012, 15:57
