Results 1 to 10 of 18
Thread: turn abs light off
    Glasgow
    Default turn abs light off
    does any one know how to turn the abs and tc wanring lights off? i dont think im gonna have time to solve the problem for the mot!
    Glasgow
    Either get the fault fixed or take the dash apart and take the bulbs out.
    Glasgow
    great result!
    loughborough
    Quote Originally Posted by byebyeitsagsi View Post
    Car will still fail if ABS light does not come on at all.
    11 Post(s)
    I thought the "bulbs" were actually LEDs soldered to the PCB.
    And as has been said, the ABS light needs to work for the MOT.
    http://www.motuk.co.uk/manual_340.htm
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yep the entire dash panel is made with LEDS, no chance of disconnecting the correct one without causing even more issues.
    Try a reset first with Tech 2 or Op-Com, may just be a temporary fault...otherwise fixing the fault is the only option.
    Have you tried disconnecting the battery overnight. - free to do, and sometimes works.
    Glasgow
    yeh mate tried a disconnect.
    think im just gna need to put it into a garage n get it done. its now or never
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    plain and simple if there is a fault that will fail an mot FIX IT or DONT USE THE CAR.
    Regular Member scottyd's Avatar
    paisley
    you can still use the car bit dramatic saying dont use it mate, try disconnecting battery or check all abs sensors are connected
    Apr 2008
    Wigan
    if it wont pass an mot it wont pass a roadside check and will be issued with a PG9 prohibition notice hence dont use
    plus will class as driving a vehicle with defective brakes and will result in an endorsement on the drivers license
  1. turn airbag light off
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 17:48
  2. Airbag light won't turn off
    By ssxanti2 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 21:49
  3. making capacitor to turn off warning light
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2009, 11:34
  4. Service Light: How to turn off?
    By barkzz in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 19:16
  5. How do you turn off the auto light switcher
    By freqfreq in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2008, 22:48
