Results 1 to 10 of 15
Thread: Noise ...
    scotland
    Default Noise ...
    hi , on my 1.8 vec there has been a noise from front left side on decceleration , soon accelerate it goes !
    I have changed the driveshaft so its not CV related , topped up box oil but still noise is there .
    it sounds like its from the g/box but all gears are smooth to select !
    noise is still there when clutch is depressed and coasting too .
    what else am I looking at here guys ??
    cheers .
    Regular Member DaveW555's Avatar
    Cannock
    Have you checked the tyre pressures and the condition of the tyre, maybe something as simple as that, other wise have you tried coasting in neutral to see if the noise is still there?
    scotland
    the noise is evident when the car is jacked and wheel spun by hand !
    not as loud tho as its slow speed .
    nowt to do with tyres mate.
    WGAF#5
    in that case wheel bearing
    scotland
    not that either mate its coming from just inside where the driveshaft enters g/box
    Cannock
    if you're 100% its not a wheel bearing and its not the tyre or cv joint then all roads point to diff/gearbox i'm afraid, the 1.8's do suffer with gearboxes for some reason, I assume its an f18 box in it? if so there's plenty in the breakers yards, you'll be spoilt for choice lol
    scotland
    surely its easier than a g/box ? should i just leave it till it gets much worse ? or will this be detrimental to the engine etc ?
    Cannock
    The diff will probably self destruct and could smash the driveshafts to bits at the cv joints as for engine damage, who knows?
    scotland
    just had a second opinion from a mech , its the diff so a new box it is , time to start saving pennies me thinks
    on the upside he said it aint an emergency and still plenty driving left in it
    Cannock
    I am a mechanic cheeky! Depending what you want to spend there's loads of choice, you could take the chance on one from a scrappy for about 100 - 150 quid, buy one from the stealers probably 1000 quid plus or recon the one you've got for about 5-600 quid. then all you gotta account for is how much someone's gonna charge you to remove/refit the box or if you're gonna have a bash at it yourself, then all your gonna need is some gear oil and patience.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
