quick question,
i have some led bulbs 501's but they strobe in side lights,
can i put these in my interior light,
if so how do i take out the unit ?
quick question,
Yes, easiest way it to remove the blanking plate/sunglass holder or the interior sensor part, then push the cover down.
take out sunglasses holder then just push down on the light fixture?
i didnt want to break it
Yeah, take the sunglass holder out, then you should be able to see the clear lense clips, just push them down and it'll pop off...
I find this the easiest way as its all by hand, saves marking any of the interior using keys or small screw drivers...
By the way, which leds do you have... the normal rounded tip style or the inverted/flat head type?
You'll be ok then, i've tried a few types and the normal style shine a bright 2p sized light straight down on the lens and have a weird light spread. flat or inverted are better and closer to a real bulb for spread
still cant see how you get them in ..................
any one help with numpty instructions ........................
