Thread: Fault Codes
    Shrewsbury
    Default Fault Codes
    My car is struggling to run smoothly at the moment especially at tick over. I think the ECU is doing somthing to compensate as it increasing the revs to 1000 rpm rather than the usual 750- 800. No EML has come on but is it possible that there are still fault codes recorded.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by chief29 View Post
    follow the how2 for fault code reading for free see if you get any codes,
    is it a 2.0dti you have?? is this on cold starts or when hot?
    Regular Member crespo's Avatar
    Bournemouth
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    engine ??
    Shrewsbury
    2006 v6 cdti 184 must update my profile from the old 2.0dti. Well only had it 3 years and 1 month no need to rush!!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    same as mine you want vx to reset learn values for the injectors and if that don't work the full sps then same again. mine is having this and the scv pump valves done wed but mine was so rough that engine light would come on due to a misfire. in agila courtesy car till then
    Shrewsbury
    Around 12 months ago it had a new injector and it feels exactly the same now. Last time I was reversing the car into the space at the dealers and the EML came on which was a great result no need mimic strange engine noises at the service desk!
    I have a car booked for Thursday/Friday but usually it is usually a Corsa. I refused the old shape Agilas after an incident on a roundabout where I am sure there was air between the drivers side front wheel and the ground. I haven''t tried one of the newer versions yet but they could only be better.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no new agila twisted steel and sex apeal. thats what the reset does so injectors aren't just changed
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
