Thread: Steering removal
    Great Ayton N Yorks
    Default Steering removal
    Can anyone tell me how to remove the steering wheel in a Signum
    Thanks Phil
    [Ex]Admin Duncan's Avatar
    PDFs.......
    Steering wheel removal
    Driver's airbag removal up to MY 05.2003
    Driver's airbag removal after MY 05.2003
    DISCLAIMER: AIRBAGS ARE EXPLOSIVE DEVICES AND THEREFORE CAN BE DANGEROUS. The instructions above should only be followed if you have complete confidence in what you are doing. If in any doubt, leave to a professional.
    Being a Signum is should be after MY 2003.5, but just in case it's not then I've put both airbag instructions.
    Basically there was a change in 2003.5 where it went from having one connection to the airnag to having two - so you'll see straight away which one yours is.
    HTH
    Great Ayton N Yorks
    Default Steering Wheel
    Cheers Duncan just what I needed
    Phil
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by philjs View Post
    Phil
    You wont be saying than when you try to do it lol
    Shame u was not nearby as I woudl have done it for you
    Nov 2007
    Leicester
    Is this the same to remove the steering wheel on the vectra C?
    Also is it possible to fit the facelift steering wheel to the vectra C? Will all of the controls still work?
    the wheels all remove the same way, and OBSERVE THE SAME CAUTIONARY NOTICE.
    Because of the way the car is internally wired, it will cost you over £1800 to fit the later scroll wheel to your button'd steering wheel..none of the controls will work and it will fault like mad..don't bother..
    Nov 2007
    Leicester
    Thanks mate, I thought if it was a straight swap then it would be worth doing it, however after what you've just told me I tihnk i'll leave it.
    Are there any other straight swaps/upgrades you can have from the facelift that will fit direct?
    in most cases, the best upgrade are from higher specced early cars.. they are fully loaded compared to the facelifts... early facelifts and late pre facelifts were by comparisom quite stripped of all the nice toys..
  1. steering wheel removal.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 10:38
  2. steering wheel removal help
    By Даниил in forum Styling
    Last Post: 18th April 2012, 21:32
  3. Steering wheel removal
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 20:05
  4. Anyone help me out with removal of vxr steering wheel please!
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 21:31
  5. Steering wheel removal??
    By alid32 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2007, 19:25
