Results 1 to 10 of 16
Thread: CD70 and steering wheel controls not working
    kent
    Default CD70 and steering wheel controls not working
    Hi
    ive just upgraded my CD30 to the CD70 which came with the matching screen, it all work OK but the controls on the steering wheel don't work. Also when i set the ignition logic on so that when i turn of the ignition it should shut down it doesn't and stays on.
    I have tried to find the answer by searching the forum but similar problems seem to be sorted by disconnecting the battery which is have done with no success.
    any suggestions would be much appreciated.
    kent
    Also I have noticed that the lights on the front panel don't work even when the side lights are on. Could the problem be a fuse.
    Have you checked all the connections on the rear are secure?
    kent
    ive just had the unit out again and all the connections are secure. Ive just found out the the unit was out of a 2009 vivaro, will this need to be programmed to the car.
    Mar 2007
    North East
    It's quite possible that the vivaro didn't have steering wheel controls and so they will need activating. I think you might need the security codes for this.
    kent
    ive got the code, ill get someone with a tech 2 to have a look at it. Do you think that the lights on the radio will need to be activated as well
    Mar 2007
    North East
    Not sure about the lights, I'd check the fuses first.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you checked the sockets in the steering wheel boss.
    I did this exact modification to find that the receiver sockets are just flat plates with no pins in.
    The plugs on my wheel switches are also blue 3 hole female items (no pins), hence no connection.
    Mine is an 05 pre-facelift full-can Vectra.......CD70 and CID are from a 06 facelift vectra.
    I will need to remove my air-bag and the metal backing plate to have a proper look!!
    kent
    Quote Originally Posted by Robsey View Post
    what am i looking for behind the air bag, the controls were working with the CD30 last week. Are the wires for the CD70 radio controls in a different place to the CD30.
    Before i take of the air-bag i will put the cd30 back to make sure that this all works as its the easier option for now.
    Where will i find the fuses for the radio, are these under the bonnet.
    thanks
    Quote Originally Posted by bret.c View Post
    Pasenger side dashboard fusebox, IIRC. The handbook will tell you.
  1. Steering Wheel Controls Not Working
    By Cruize in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 10:40
  2. CD70 - steering wheel button stopped working
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 10:41
  3. Steering Wheel Controls Stopped Working
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 16:39
  4. Steering Wheel Controls, Stopped Working!
    By bigcarman79 in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2009, 18:10
  5. steering controls not working
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2009, 20:27
vectra c steering wheel controls not working
2003 vectra c remote steering wheel functions problems
opel vectra radio controls not working
vectra c steering radio control fix
cd30 buttons not working
vauxhall cd70 steering wheel control button not working
vauxhall cd70 radio station select not working
vivaro steering column controls not working
where do my vectra steering wheel controls plug in to a cd70
cd70 volume control
vauxhall vectra steering wheel controls dont work
vauxhall vectra steering wheel controls dont work and tip controls
vaxhall singnum. radio. on stering not work
fusible cd70 navi
cd70navi stearing wheel issues vectra c
zafira a steering wheel radio controls not working
radio controls not working on my steering wheel on vectra c
2007 vectra steering wheel volume control
vectra program display volume steering wheel not working fuse
vectra cdti steering wheel radio controls not working
vectra stereo controls not working
vauxhall vectra c radio control not working
opel vectra c screen control
