Thread: strange fault symbol!
    Regular Member oldcommando's Avatar
    kent
    Default strange fault symbol!
    hi guys.
    i hope you can help here.
    i (rather stupidly) took the car through a mechanical xar wash the other day that also done an under body wash.
    now since driving away i have noticed a symbol on the display showing a kind of circle with 2 dots on each side?
    any ideas?
    you guys are good on here, so thanks in advance!
    ross.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Front Brake Pad wear indicator? Or maybe the sensor for it is faulty?
    Dunstable
    Is it like this symbol? If so then yes is the brake pad wear sensor. Check the brake pads to make sure they're not too low, could be a dodgy sensor, or water may have got into the sensor and may dry out. Try taking the car for a long run, it may clear the fault.
    kent
    thaknks guys yes it looks just like that. will sort it.
    cheers guys.
  1. strange heater fault
    By DAVIDD88 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 21:27
  2. Steering Wheel Fault Symbol ON !!
    By Bobarache in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2011, 09:37
  3. strange symbol....
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 23:30
  4. Strange fault
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 15:52
  5. Fault symbol after cambelt change
    By Harro in forum Engine & Drivetrain
    Last Post: 19th February 2008, 19:26
