Results 1 to 10 of 11
Thread: Drop links....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Drop links....
    how long should they last? changed mine just over 2 weeks ago and i think they could be knackerd again . As the knocking noise at the front has started again today (not same noise as before i changed the links)
    can you buy up rated links?
    VOTING UKIP IN AVELEY
    14 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    should be way longer than 2 weeks..i.m guessing youve cked your springs ...could also be top mounting bearings...cant remember why now but when Plasma changed his once they didn't sit quite right and the rubber seal perished ...worth a ck too
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by soulman View Post
    cheers mate, PI springs are ok checked last week (not a year old yet)
    how much are strut top bearings?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    while your at it check your wishbone, under the hub area.. easier to take the wheel off to check this,
    in this pic below from the how2 on changing front disks you can see the wishbone just below the wratchet.. this joint has a vertical pin about 1cm diameter that inserts upwards into the bottom of the hub (not sure on actual part names here), this area can knock like gooddun and you can easily miss it,, replacement wishbone range fron 50 to 90 quid, not hard to replace..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Start small mate, check the arb bushes on the front, they will give a rattly knocking sound
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Also the rad mounts. I even solved a suspension sounding noise when I found out my exhaust hangers had rusted through.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    sounds like its coming from inside the turret? if that makes sence
    14 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by bobby-tupper View Post
    do you only hear it when turning the wheel ??? cos we have found that the torx screws holding the top mount can sometimes be a touch to long and foul the spring.a couple of washers underneath cured this fault
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    it only started doing it a month ago,so changed the drop links and was ok for a while now the sound has reapeared
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    By any chance have the drop links slackened off again? I've had this happen before
  1. Drop links or not!
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 09:29
  2. Drop Links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 20:06
  3. drop bar links
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 09:57
  4. Drop links
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 21:45
