Thread: Buzzing from rear fuse box :(
    New Member dazmanz's Avatar
    Pontefract
    Default Buzzing from rear fuse box :(
    Hey peeps... anyone any ideas... just had a towbar fitted all electrics working fine .... heres the thing, i have a buzzing coming from the fuse box until i press the brake then it stops until i depress it and its back again .... all electrics working on the car fine its just the buzzing you can here from the rear fuse box...
    Any ideas??
    1.9cdti design
    vectra c 56
    150bhp
    Dunstable
    Could be a dodgy relay. They can make a buzzing sound when they have had it, you'll have to listen in the area when you're stationary and try to hear exactly where the sound is coming from
    Regular Member axelf's Avatar
    chester le street
    i have this same noise but only when connected up to the caravan.....and engine switched off
    liverpool
    I had a similar problem last year except that the buzzing was there continuosly. when I looked at fuse box in boot . I found a wire that had a spade on which was pushed into an empty fuse socket .This wire was loose at the socket i pushed it back in and the buzzing stopped.
    Pontefract
    Thanx for your replys guys... just been in and taken a closer columbo inspection and found where the noise is coming from.. its a black box where all the wires go into from the lights which i think is what the garage fitted with the towbar.... its just its really loud and annoying... grrrrr
    Back to the garage tomorrow me thinks as i only just had it fitted...
    Thanx for all your advice...
  1. Rear fuse box
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2011, 13:43
  2. rear fuse box Q?
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 17:03
  3. rear fog lights fuse
    By stevelee in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 12:32
  4. rear fog light fuse
    By thedrive in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2009, 19:11
  5. Rear window fuse
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2008, 00:57
vauxhall vectra cdti buzzing noise when lights are witched on.
vauxhall vectra cdti buzzing fuse box when lights are on
vectra 19cdti buzzing noise after switching in of
vauxhall zafira beep from rear when fog light is on
zafira relay buzz when lights on
