Results 1 to 10 of 16
Thread: Oh Man, what have I done??? Urgent help required!
    Regular Member Nav-Man's Avatar
    London
    Default Oh Man, what have I done??? Urgent help required!
    Hey guys.
    So, my 2002 Vectra C was losing power in first gear when taking off from junctions, traffic lights, etc. After reading a few threads here, I've changed the EGR valve, slight improve, but still stuttering a bit.
    just now, I've changed spark plugs, air filter, cleaned the throttle body using a toothbrush and carb cleaner and also sprayed carb cleaner down the inlet manifold and brushed all the gunk off.
    The problem is, now, when i start the car, not only the 1st gear problem remains, but now, the car idles like s**t.
    Clearly, I've done something wrong. So i would like the help of you guys to try and sort this problem out, before I have to take to a Vx dealer, who will probably tell me that i f****d the engine up and now will need a new one.
    PLEASE, PLEASE, PLEASE, HELP!!!!
    Regular Member RobW's Avatar
    Tain - Easter Ross
    There's maybe a bit of gunk lodged somewhere, something you missed. Try taking it for a wee blast?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like you may have knocked crap into the inlet manifold when cleaning, as Rob said take it for a hard run to try and clear it out a bit.
    And needing a new engine may be a bit extreme
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Sounds like it's not getting enough diesel to me XD
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by nutron View Post
    I think diesel may make the problem worse lol (petrol car )
    wellingborough
    i had this problem and it was loose connection on one of the leads when i changed sparks
    London
    Quote Originally Posted by niicckk View Post
    My 1.8 engine has a bar with the connectors to the spark plugs on it and this bar connects to a little plug thing, no standard spark plug leads, so not sure how to check if the leads (if any) are ok.
    Is there a way to clean the inlet manifold without having to remove it?
    Man, I'm panicking, I thought I was doing a good work, BUT, somehow I've messed it up...
    London
    Quote Originally Posted by Nav-Man View Post
    Err... found out the correct name for the "bar" is Ignition Module. I'm going back out again to try and sort the problem out... Wish me luck...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Doubt you have done alot of damage, but I would suggest making sure you have tightened up all bolts/screws you removed from the engine and also when you changed the spark plugs - check you havent accidently crosed the threads for these.
    PS - try not to spray carb cleaner into the manifold either
    Gazza4
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Yea, if its anything like the 2.2 you will have dislodged a load of carp. As said take it out for a good Italian tune and I think you might sort it. My moneys on all the oil and carbon in the manifold being dislodged.
  1. Urgent help required.
    By floppus in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 11:50
  2. **urgent help required**
    By hogg537 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 12:40
  3. urgent help required
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2009, 18:00
  4. URGENT Help Required
    By Phil MC in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 13:38
  5. urgent help required
    By sulky_uk in forum General Chat
    Last Post: 22nd February 2007, 18:55
