Thread: Anyone a plumber ???????????
    Ireland
    Default Anyone a plumber ???????????
    Any plumbers on here ? I need some Fire Hydrant advice before I flood my entire street.
    Regular Member nigec's Avatar
    barnsley
    Yeah, what advice would that be, sounds like a fire engine required !
    Ireland
    Nige, I have a FH at the bottom of my drive (in a service strip). It used to be "level" with a grass border but the grass has been dug away ready for me to widen my drive. The FH cover is now about 10" above the ground which would normally by easy to lower but the valve itself was flush with the cover.
    I`ve removed the cover/concrete rings etc and dug down to the main water pipe and the FH valve is T`d off the main pipe with a section thats 10" long, so I need to unbolt the valve and this 10" piece then bolt the valve back on, except I don`t know how to turn the supply off to the FH, the water board have refused to come and do it and my neighbours are getting very worried.
    barnsley
    To be honest pal if its an actual fire hydrent that the fire brigade use to connect to then id leave it well alone, dont think your even allowed to mess with them, if its a normal stop tap on the street then its down to the water board, if its on your boundary then its up to you to sort it. Hth
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Think you can actually be prosecuted for mucking around with fire hydrants mate. You may want to put it back as was and take professional advice on it first.
    Ring the fire service???
    Regular Member Marcosuk's Avatar
    Fife
    U have to contact your local water board & they will put a lower 1 in for u..
    Expect to pay big £££ for it tho... I cant remember off hand but up here it used to be up to £1000
    Mar 2007
    North East
    Your local water company are the only ones who can do this but they will charge.
    scotland
    yip as said before DONT mess with the ring main !!
    I'm a FF and believe its a water board job to move it for you .
    unless you can bring your level up a bit and leave enough space between lid and outlet ( distance I dont know ) .
    good luck an dont screw it up as it could be needed at your place ... god forbid
  1. Is there a plumber/gas man here?
    By beat275 in forum General Chat
    Last Post: 27th January 2012, 14:01
  2. Anyone know a good reliable plumber?
    By wingz123 in forum General Chat
    Last Post: 22nd May 2011, 19:16
  3. any plumber merchants out there
    By kevin hunter in forum General Chat
    Last Post: 10th December 2008, 16:00
  4. gas fitter/plumber in birmingham?
    By Nickzx6r in forum General Chat
    Last Post: 3rd May 2008, 14:29
  5. Plumber needed?
    By blr123 in forum General Chat
    Last Post: 21st March 2006, 19:49
