Thread: help please car missfiring
    Regular Member samngeorge1985's Avatar
    lanark scotland
    Angry help please car missfiring
    it is a 1.9 cdti 150 bhp which is as if it is missing, the engine management light has came on, it wont go above 3000 revs when driving or idling and no power, im thinking its the air flow meter what you guys think any help is a big help
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    could be 3rd injector wiring or the EGR valve, both are in the 'how 2 section', pm if you get stuck!.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I would say it is the 3rd injector loom from what you explain as mines was doing the same 2 weeks ago. I unplugged injector 3 (third from the cambelt side of the engine when looking at the front of the car) and blew on it then plugged back in, the car ran perfect for 20miles then the engine got wise there.
    The upgrade loom is about £12 and £80-£100 for the dealer to do.
    But also get the fault codes read before you do anything
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    For an easy test try spraying electrical contact spray into the 3rd injector plug (3rd from left 2 right) and it should give good results, if not try the others 1 at a time! to eliminate the problem 1.
  1. another missfiring question.
    By burbling1 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 21:25
