Results 1 to 10 of 15
Thread: Shower Gone Cold, any ideas?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Shower Gone Cold, any ideas?
    Anyone know any reasons why a shower would suddenly go cold..
    If I turn it up to the highest setting it's luke warm rather than cold.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    No hot water!!
    Ashington, Northumberland
    The element in the shower has gone mate. New shower time as it wil cost more to fix than to renew altogether.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I'm guessing its and aqua shower where the water gets heated as it passes through .mine use to last a couple of years in hard water area.........the eliment gets fooked up ...as gary said get another one.
    @home
    Engine : 1.9 CDTi
    It's an electric shower (http://www.shower-spares.co.uk/triton/T300si.htm)
    Problem is the holes in the tiles are already cut for this type so it would mean more work to fit a different design. I may just try and fix this one or replace the whole power pack (fig 7).
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    can you not get something of about the same size, will be a cheaper option that replacing all the faulty internal's....
    Midlands Mod Shop - NFFC.
    Worcs/Staffs/Westmids (ish)
    My electric shower just went, fixed it the same day....
    http://www.vectra-c.com/forum/showthread.php?t=108841
    Its extremely common for the pull cord switch contacts to burn out, in my case it was a combination of the switch contacts and the dodgy wiring.
    But if you use the pull cord to turn off/on your shower it will burn out in no time at all.
    @home
    Engine : 1.9 CDTi
    I've ordered a heater can assembly at £60. Let's hope that's the culprit.
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Mileage : 56000
    I have a triton t110xr which has started cutting out to cold, the low pressure light comes on. The problem was the PCB (circuit board) which cost me £69 from Triton. I can get a new shower for £120, so maybe should have done that.
    2.8T Signum Design
    @home
    Engine : 1.9 CDTi
    Got the new heater today went to fit it and noticed the pcb has a burn mark on one of the connectors to the heater assembly (only noticed this when I was trying to remove one of the wires to the assembly, the pin has now just come completely out of the board)!
    So I'm not sure which part has caused the other part to blow????
    Looking at another £60 for a new PCB
  1. Meteor Shower
    By ChrisBilly in forum General Chat
    Last Post: 3rd August 2010, 13:20
  2. Shower
    By moorlander in forum Comedy & Humour
    Last Post: 13th November 2008, 22:45
  3. Do you and your partner shower like this??
    By Craig1985 in forum Comedy & Humour
    Last Post: 2nd October 2008, 19:50
  4. Had a lovely shower
    By PeterVV in forum General Chat
    Last Post: 13th November 2007, 23:57
  5. anyone want a shower?
    By pogo in forum General items for sale
    Last Post: 11th November 2006, 10:41
