Thread: speedo clocks
    slough
    Default speedo clocks
    hi guys and gals anyone ever changed the dash clocks on the vectra c 1.9 ctdi from the one with only one small window in the speedo to the one with two small windows, the reason i ask is i miss the extra window that not only tells you a door is open but wich one as well. if you have what problems did you encounter was is it easy. and oh yes before you ask yes i do have more money than sense
    member of the smoke patrol 230bhp+
    its one out and one in
    20 mins and its all done
    Mileage : 000
    It does help if you have more money than sence on this forum. Good luck with the clock change. If the "replacememnt clocks" are second hand you will be stuck with that milage. But your original will still be in the ECU memory if my memory is correct.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by ed taylor View Post
    Correct, ECU stores the correct miliage.
  1. speedo clocks
    By paul.sessions in forum Parts for sale
    Last Post: 13th February 2011, 10:00
  2. Speedo clocks
    By K18 JRT in forum Styling
    Last Post: 19th February 2010, 19:29
  3. Speedo Clocks
    By Simo87 in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2009, 19:57
  4. speedo clocks on a 1.8 ls
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 20:45
  5. speedo clocks
    By pipcurry in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2007, 23:05
