Thread: which battery 096 or 075 and how easy to fit?
    Sep 2009
    St Albans Herts
    Default which battery 096 or 075 and how easy to fit?
    these seem to be the numbers i have come up with, its a 2005 1.9 cdti 150
    think mine is on the way out
    Full Member Big Sig's Avatar
    Very easy to fit. Most places will tell you what you need - which one. Just make sure that if you need the radio code you have it.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    If I have to disconnect battery without upsetting radio I usually run jump leads from car wiring battery connector to new battery, disconnect old battery, lift new battery in, put connector on, then remove jump leads.
    Sep 2009
    St Albans Herts
    Quote Originally Posted by Grumpy1954 View Post
    searched web and came to conclusion mine would be ok, bought battery from costco, bosch s5 (s0007) £70.49 with 4 year guarantee.
    just changed it without connecting charger, then reset windows, radio reset time and date automatically (cd30) all went fine
    cheapest other battery was eurocarparts at 54 quid battery for a diesel is an 096
    The cd30 is full canbus so no radio code is required
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  4. How easy is it to...
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 1st March 2009, 23:03
  5. IT help: how easy is it to....
    By Harry in forum The 'Off Topic' room
    Last Post: 3rd March 2008, 20:24
