Thread: whats wrong with my veccy???
    Regular Member storm's Avatar
    Northumberland
    confused whats wrong with my veccy???
    hey guys need your help with this one,at around 1500 rpm the car hesitates for a second or two?like it has something jammed stuck etc. it just doesnt seem to be running right, i has had a new egr 2k miles age with the fiat gaskets and has been running really smooth just seems to have developed this fault! Last weekend myself and a friend cleaned out the throttle body so again just done. Please help guys im losing to will to own my vectra so im all ears
    May 2007
    West Yorkshire
    do a search, very common issue
    Warrington
    Storm, mine is doing the exact same. It kangaroos around the 1700 - 1900 rpm mark mainly in 2nd and 3rd gears. I have had the ERG valve cleaned out as the alternator recently went on it and though i would have it checked out. It has made no difference and since the engine management light has come on! I am just about to give up on the Vectra as i have shelled out about £600 so far this year, it might be time to go to the 3 series i think. Has your engine management light come on?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    See threads by Vaux-Man-G he is having the same issue
    EDIT : Here is one of his posts http://www.vectra-c.com/forum/showthread.php?t=109426
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    3rd injector..? Or an injector semi blocked.
    Northumberland
    Scarface sorry to hear about your veccy!I havnt had any warning lights yet but have noticed my boost pipe had moved a bit up at the throttle body and has been spitting oil out! It also has had injector cleaner run through for the last few tanks of diesel so hoping injectors are clean! Is there a way to check injectors?
  1. Whats wrong here?
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2012, 14:37
  2. whats wrong here ????
    By ditchp in forum The 'Off Topic' room
    Last Post: 15th June 2012, 01:44
  3. whats wrong with this pic 4
    By neill in forum Comedy & Humour
    Last Post: 6th February 2012, 14:39
  4. Whats wrong here then?
    By Ziggy in forum The 'Off Topic' room
    Last Post: 22nd December 2010, 16:12
  5. whats wrong here?
    By Dose in forum The 'Off Topic' room
    Last Post: 25th April 2009, 18:52
