Results 1 to 3 of 3
Thread: Whooshing, Oil & Smoke
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Whooshing, Oil & Smoke
    Hi Guys. I've had a whooshing noise for some time now, coming from under the bonnet when flooring when pulling away. This whooshing has gotten worse recently. It happens under normal acceleration now. Today, on my way back from work smoke began occuring!... black i think, maybe with a bit of blue. I took it to my local garage and instantly the young lad piped up. BOOST PIPE! He reckoned i've got a split boost pipe. Upon opening the bonnet i found fresh oil here.....
    Right infront of the radiator on the inner bumper lip.
    He suggested to me that there might be some oil being fed into the boost pipe. Is this so? and is it normal? Also where is the boost pipe that might be split?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would say the intercooler is burst
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by benny View Post
    Just looked underneath and the plastic tray has a fair bit of oil on it as if something has burst. Is it replacement intercooler time or is there a fix?
  1. Whooshing sound when changing gear....?
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 15th September 2011, 09:02
  2. 2.2DTi loss of power, whooshing noise and excessive smoke
    By Mogsy007 in forum Engine & Drivetrain
    Last Post: 7th September 2011, 10:22
  3. turbo whooshing noise (not normal)
    By robshortman in forum Engine & Drivetrain
    Last Post: 24th April 2010, 13:17
  4. whooshing noise from a belt?
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th March 2010, 10:38
  5. Whooshing noise
    By macane in forum Engine & Drivetrain
    Last Post: 5th January 2009, 22:17
