Thread: Rear Hatch Lock Adjustment?
    Mar 2007
    Attleborough, Norfolk
    Default Rear Hatch Lock Adjustment?
    Some times when I close the rear hatch on the Vectra and it doesn't close properly, I have difficulty opening it again. When I press the button there is a whirring noise, the hatch will lift slightly but won't open. In the end it is a case of yanking it up until it opens.
    Have any of you had this happen? Is it anything which can be adjusted?
    Thanks.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Mine does this too at times on the Signum.. and there were times in the Winter where the button wouldnt even activate and the boot was stuck locked for a few minutes.. then it worked again lol! Crazy
    Aug 2009
    LEEDS
    there's a fault on them, if its still under warranty take it in to dealers. my mate changed mine before it went when i got the car!
    south wales
    yes i have the same problem but cant work out if i need a new lock or the piece on the bottom any one know? what got replaced under warranty?
    Mar 2007
    Any suggestions anyone?
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i would like to know if you can adjust them as i have to give mine a good slam to get it to shut properly
  1. hatch adjustment
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2012, 14:52
  2. Rear Camber Adjustment
    By spoons in forum Handling & Braking
    Last Post: 10th November 2010, 22:00
  3. Quick question - Rear Washer Jet Adjustment (08 Plate Hatch)
    By king_chris in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 02:02
  4. Vectra hatch won't lock
    By SpooRancher in forum Bodywork & Interior
    Last Post: 3rd November 2008, 21:41
  5. Estate Rear Camber Adjustment
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2008, 08:26
vectra c boot lock adjustment
