Results 1 to 10 of 20
Thread: battery light
    Edinburgh
    Default battery light
    Chaps,
    Just wanting to confirm something with you. Out driving down the bypass tonight my battery light came on the dash. Got multimeter across the battery terminals, when battery only its reading 11.8v, when engine running it's reading 11.5v, am I right in saying my alternator is on the way out? (rather than it being the battery)?
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Looks that way mate get along to kwik fit and get them to test the battery just to make sure, batteries can load the alternator if they have cells down, cheaper option anyway.
    Edinburgh
    will do
    If it does need replaced, I looked at the how-2 and would give it a shot myself, but nervous about touching belts, how easy are belts to refit after removal?
    Also, am I ok to drive it still or am I likely to conk out somewhere?
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Once the tensioners are loose it is fairly simple as it is for taking it off
    Edinburgh
    ok the next question is are all alternators for 1.9CDTi's the same?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Less than 12v at battery I'd suspect a cell down. Best get both checked. You have to take belts off to change battery? I thought the headlight bulbs were crazy!
    Edinburgh
    belts off to change alternator, not battery lol. I'm thinking it is the Alternator because I think I have the flatspot below 2000rpm mentioned here:
    http://www.vectra-c.com/forum/showth...=battery+light
    Euro Car Parts list 4 different alternators though
    Regular Member LADmachining's Avatar
    Hampshire
    Probably a selection of current ratings available.
    Most common one is 100A. The rating is usually printed on the black plastic rear cover, or engraved somewhere on the casing of the alternator.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Big Knox View Post
    Interesting link, yes, electronic ignitions would be affected by low volts as well as everything else. Good luck with it, hope you get it sorted. I always check the cheapest thing first lol. Had an AA patrol tell me once I "had" to have a new alternator. I asked if the wire hanging off underneath was related - it was, new connector, fixed. £100 fault down to 10p one.
    Regular Member jonny p's Avatar
    wirral
    i had to get a new altenator last year when my car had only done 34k..... ebay ya best bet 85 quid exchange..... rather than £230 from the stealers
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. battery light on along with spanner through car light
    By conny in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 13:45
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
ford kuga battery light on
