Results 1 to 3 of 3
Thread: 1.9 cdti 120 timing belt cover help
    PRESTON
    Default 1.9 cdti 120 timing belt cover help
    I have a 2006 1.9 cdti 120 Vectra. Does anyone know if the timing belt black upper cover can be removed without first removing the upper part of the engine mounting. When i purchased the car, the trader said he had changed the cambelt, but i am sure i can hear a bearing type noise from the cam belt area and i suspect if he has changed the belt, he hasnt had the water pump done and need a fast way to check it out,
    Cheers.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Its got one 13 mm bolt that you cant get out unless you remove the mount, You can break the lug off if you dont want to remove the mount but wouldnt recomend that
    PRESTON
    Cheers alan,
  1. Timing belt cover bolts question 1.9 cdti 150
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 7th February 2013, 13:54
  2. socket for timing belt cover
    By craig20102010 in forum Engine & Drivetrain
    Last Post: 22nd November 2012, 10:48
  3. where to get 19 cdti 150 timing belt kit?
    By ronnie63 in forum The 'Off Topic' room
    Last Post: 25th August 2012, 17:24
  4. timing belt kit CDTi
    By Derek Mc in forum Diesel Engine related
    Last Post: 19th August 2012, 16:44
  5. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
