Results 1 to 10 of 27
Thread: Rear shocks - tools required???
    Aldermaston (Berks)
    Default Rear shocks - tools required???
    Hi all, need to change my rear shocks rear drivers side is shot. I have asked a friend about changing them and he seems to think i need spring clamps for the rear - is this correct???
    The car in question is the 2.2 sri dti 2003, i have had a quick look behind the wheel tonight & i cant even see the shock lol although light is fading as quick as my eye sight.
    I have had a look at the how 2 and there is no mention of spring clamps, are there different setups across the range on the vec c?
    Cheers all.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    No spring clamps are needed, as the shock is on its own, bolt at the top and bottom.
    Sunny Dartmoor
    Don't need springs clamps,just use your jack under the the arm and lower it down gently and remove the spring,hth..........
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As said you won't need spring clamps but a set of torx sockets will make life alot easier
    Aldermaston (Berks)
    Ok thanx guys much appreciated.
    Keith
    A T18 & T20 iirc as i did mine the other week
    Aldermaston (Berks)
    Pretty sure i got both of them.
    Nov 2009
    Lancashire
    I'm about to do this too on my Signum (why are Vx shocks so crap?!)
    I don't have any Torx sockets so will need to get some.
    Do I need E18 & E20 to do this job?
    Cheers.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes you need E18 and E20.
    Just changed mine this weekend. and peferable axel stands or 2 jacks..
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Guys, what shocks have you bought?
    My Sri ones are shot on the back at 48,000miles!
    Ive been looking at bilstein b4 or monroe ones.
    I dont want to lower the car due to clearance issues on my drive so ging for standard ones again.
  1. Tools required for oil & filter change
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:15
  2. what tools do i need for rear brakes on 2.0 dti?
    By MCD in forum Handling & Braking
    Last Post: 10th March 2011, 17:47
  3. New Shocks & Springs Required
    By themarbleman in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 20:07
  4. Tools required for 2.0DTI Plug Change?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th December 2010, 20:16
  5. Replies: 39
    Last Post: 26th July 2008, 22:40
tools needed to change vectra rear shocks
