Thread: brake calipers
    liverpool
    Default brake calipers
    my n/s rear caliper was seized but the mechanic managed to free it off.he advised me to source another caliper as the crap would get in again due to the rubber seal being shot.my question is,is another caliper necessary as im sure i read somewhere you can buy a seal kit ????
    Sunny Dartmoor
    Yeah you can buy a new rear seal cap from Vx they're only about £6 i'll try and get the number for you...............
    93187990 PROTECTIVE CAP £4.88 + vat
    liverpool
    cheers glen
    Regular Member Pete B's Avatar
    Malvern
    I've just replaced this cover on one of my rear calipers after finding it split while changing the pads a couple of weeks back. The piston etc was fine so it hadn't been like it long - it's even conceivable I could have caused it while winding the piston back with long nosed pliers as the tool adapter I bought didn't fit, even though it said it was for the Vectra (maybe the older 'B' but it didn't specify that).
    One point of note though, the piston end of the seal fits into a groove round the piston circumference but there is no recess in the circumference face round the caliper body for that end to fit into. I could only therefore assume some sort of adhesive/sealant is used to stick it to the smooth seal face surface on the caliper body.
    In the absence of knowing exactly what adhesive/sealant to use, I used "superglue" but I don't know whether that is correct or not. Any advice please?
    I'll be checking the seal again in a couple of weeks time to make sure it has remained in place sealed to the caliper body seal face.
  1. Brake Calipers
    By viper8 in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2012, 17:45
  2. Brake calipers
    By Derek Mc in forum Styling
    Last Post: 8th May 2010, 19:58
  3. im getting my brake calipers done help!
    By dannyjpuk in forum Styling
    Last Post: 1st March 2010, 01:00
  4. brake calipers help
    By zazaszazas in forum Handling & Braking
    Last Post: 28th June 2009, 13:08
  5. Brake calipers
    By Spikey© in forum Detailing and Car Care Discussion
    Last Post: 26th March 2006, 21:03
