Results 1 to 10 of 14
Thread: Radio problems: no steering wheel control, no display
    Regular Member FinnRolo's Avatar
    Dublin, Ireland
    Default Radio problems: no steering wheel control, no display
    Hi,
    Wondering if anyone can offer advice on how to resolve the following radio problems with a 2005 facelift Vectra:
    Steering wheel controls not working
    No display when radio turned on
    Radio staying on when key is pulled out of the ignition
    I guess I should start by checking fuses, if only I knew which ones to check (on the passenger side panel)?
    I did do a forum search, but have not managed to find a thread from someone with the exact same problems.
    Any help offered greatly appreciated.
    leeds
    Mine did this once and it just turned out to be my mp3 CD which I had in at the time. It must have been a dodgy recording as I re recorded it and all was well. Just take out the CD then cycle the power off and on.
    Hope it works for you.
    st helens
    Mine has done this once just dissconected and reconected the battery and it seemed to reset its self just make sure you have the code i didnt and its 25 quid to get the code from vauxhall
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    being an 05 vectra, you wont need the radio code.
    First try the battery thing for a few hours.
    Fuses to check otherwise are:-
    Fuses 1, 7, 9, 10, 12, 17 and 26 in the end of the dashboard (near-side / passenger-side).
    Most common is F12, but the last time this happened on the forum (last week), disconnecting the battery solved it.
    Dublin, Ireland
    Thanks for the suggestions guys, will try them out and update.
    Brighton
    Hello,
    Did disconnecting the battery work? The same has just happened to my 06 Vectra.
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    As yours is full canbus, you also can disconnect your battery without needing to worry about the radio code.
    I guess you've checked the fuses in the passenger end of the dash panel.
    Brighton
    Thanks for reply.
    Only noticed last night, so a job for the weekend!!! Will check the fuses first as you have mentioned.
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by AS007 View Post
    Thanks for reply.
    Any outcome to this?
    If job done, then what fixed it?
    milton keynes
    having exact same problem,tried fuses and disconnecting battery still the same!
    anymore ideas people?
  1. Steering wheel radio control Kenwood
    By daugaard in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2012, 14:06
  2. Steering/Radio Control Removal
    By si_hoss in forum Bodywork & Interior
    Last Post: 7th April 2011, 18:14
vectra c stereo display fuse location
