Thread: Squealing Noise from drive belt area
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Squealing Noise from drive belt area
    Usually on cold and goes away after warmed up, does not change with revving the engine (if anything it gets a bit quieter), makes no difference if there is load on the alternator (heaters, blowers, radio etc etc) and does not change when the aircon is put on.
    Does not sound like it is the timing belt / rollers / water pump, it sounds like it is on the 'outside'
    Any clues or am I best going to a garage and pay for an investigation?!
    I initially thought the alternator but the bearing is still tight and the charge is still normal.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Sounds like the multi V belt to me.. I bought a new one for about £8 and fitted it myself (with a little help from the neighbour), was about a 5 min job..
    Tain - Easter Ross
    Multi V belt? Is that the one that goes round the alternator?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    yes mate.. sometimes the alternator pulley needs changing as well to a superceeded one (made by bosch). But start with the belt first, its very common problem..
    Regular Member DaveW555's Avatar
    Cannock
    While its running have a look at the belt itself with a torch etc and see if its flapping around, if it is then it could be one of three things, either the clutch pulley on the alternator is knackered or the tensioner is knackered or it could just be a worn belt, if it turns out to be either of the first two i'd fit a new belt as well, as all the flapping around could have stretched it. Hope this helps.
  1. clicking noise drive belt area
    By hairy31 in forum Engine & Drivetrain
    Last Post: 28th May 2012, 22:50
  2. Annoying squealing belt
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 18:27
  3. Auxiliary drive belt squealing
    By James C in forum Engine & Drivetrain
    Last Post: 26th November 2010, 08:41
  4. Squealing from cold - aux belt
    By steve in forum Diesel Engine related
    Last Post: 14th July 2009, 08:52
  5. squealing v-belt
    By tkmax in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2008, 13:06
vectra c squeezing belt from cold
z19dth squicking belt
