Thread: vxr turbo on z20net
    Regular Member stephen g's Avatar
    livingston
    Default vxr turbo on z20net
    will the vxr turbo fit the z20net or not if not what other turbos will ??
    WGAF#5
    Quote Originally Posted by stephen g View Post
    in a word no ....but
    there are several options open to a larger turbo being fitted but most others are oil cooled rather than air as current - so additional mods would be requried - then you would need a remap to cope and possibly a larger intercooler to accomodate the turbo changes otherwise the lag would negate the gains - then you need to look at a new manifold and downpipe to help the car breath better a new air intake and then possibly new fuel pump and larger injectors then dependant on the gains futher mods to the engine /gearbox and suspension and brakes = how much of a gain are you looking for
    try looking at the saab B207R (210 bhp variant of our engine) or the saab B207L same variant of our engine for some ideas - then you can look at the american series engine which has a supercharger rather than a turbo
    have a look at one of my threads here for ideas
    http://www.vectra-c.com/forum/showth...t=larger+turbo
    Leicester
    Supercharging is out of the question due to management issues and also the turbo's compression ratio is wrong for supercharging.
    As deztroyer has said, look at the Saab Aero 210bhp turbocharger which would be pretty much a direct swap with the one you have. It's a Mitsubishi unit rather than the Garrat unit the Z20 NET has as standard.
    Also as said you will need a re-map to suit. OK some will argue the standard turbo is good for 250bhp, but the Garratt Turbo is running flat out at this point and the standard injectors will be running right at their maximum duty cycle.
    By fitting the Mitsy turbo and Saab Aero injectors, at 250bhp the set up will be running at a comfortable level with room more.
    livingston
    thanks for the info guys much apreciated
    Regular Member sberrow's Avatar
    Newport (Gwent)
    Interesting thread, Ive now been running my setup for a few months running over 250bhp looking for continuity. had a few minor faults but is working. car is cappable of approx 280bhp. ive done around 5k and having a service, looking at fitting a boost control setup to give the cars potential on demand. we will see??
    [Ex]Admin Duncan's Avatar
    Waddya mean Dez? Standard Garret turbo in Z20NET is water cooled, with obviously oil circulating around turbo for the lubrication as well as a bit of additional cooling.
    Leicester
    Dunc, where you been? Not seen you for ages.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Duncan watches in the background . Waiting for when an incorrect fact about the Z20NET surfaces in a thread.
    PS, The standard Z20NET in the Vectra is 172ps.
    Where is he?
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Z20NET Turbo
    By MattHD in forum Engine & Drivetrain
    Last Post: 10th June 2011, 10:45
  3. Z20NET Turbo
    By MattHD in forum Petrol Engine related
    Last Post: 4th April 2011, 10:48
  4. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
vectra c z20net turbo lag
z20net vxr turbo
z20net supercharger
vxr z20 net
z20net water cooled garret turbocharger
