Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: "Check Safeguard" Message
    Regular Member Loz2286's Avatar
    Apr 2009
    Bucks
    confused "Check Safeguard" Message
    I keep getting this message on the display screen. What does it mean? How do I fix it?
    I'm also getting "InSP" showing up in the trip meter display.
    Thanks.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    INSP is your message that its time for a service ..the other one i havent a clue
    to reset your service light read below
    http://www.gendan.co.uk/article_6.html#vauxhall
    Regular Member denzilbud's Avatar
    cambridge
    i think its something to do with the electrics or alarm i get the same try doing a search in the search bar it will bring up loads
    11 Post(s)
    As stated in the handbook:
    Check safeguard
    Fault. System error in anti-theft alarm system. Have cause of fault remedied immediately. We recommend that you consult a Vauxhall Authorised Repairer.
    Basically you need the fault code(s) read out to identify the fault.
    cambridge
    had mine at vx and the best they could come up with is on the prefacelift there is a abs plug upgrade which if not done the old one throws up problems with all the parts wired in through the abs plug,but a good clean of the plugs contacts usually fixes problem dont know if it is the came on the car i question or not
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Do you have an Estate?
    Blantyre
    Check all your fuses in the boot area
    Apr 2009
    Bucks
    Nope, hatch back....
    My alarm has been playing silly ******s for ages.... It goes off if I set it on a sunny day. I've taken to winding the driver's window down, popping my arm in and pressing the deadlock, then bringing up the window. Is this related?
    Thanks for the info on the "INSP" message. I'll try the "how to" out a little later..
    Apr 2009
    Bucks
    Quote Originally Posted by signumboy View Post
    Thanks... that's sorted now.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Could be your switch under your bonnet coz in the sun the bonnet expands and lifts slightly moving the pin on the switch so sets off your alarm
    Irmscher Insignia CDTI 130
  1. "check light" fault message
    By danhariga in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 15:50
  2. "Check Safeguard"
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 13:59
  3. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  4. the check safeguard message
    By dansri in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 19:15
  5. "Safeguard Check??"
    By MikeO in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 18:11
vectra safeguard reset
vectra c safeguard message
vectra c safeguard check
vauxhall vectra safeguard
vauxhall vectra safeguard on display
check safeguard vectra
how to reset check safeguard vectra c
safeguard vauxhall vectravectra c check safeguard messagesafeguard vauxhall cd30vectra c estate safeguardvectra c safeguard modesafeguard message on vectracheck safeguard vectra after changing alternatorwhy does my vauxhall vectra say safeguardhow to stop safeguard coming up on my vectravectra c safeguard buttonvauxhall vectra check safeguardvectra c delete safeguardingvectra c safeguardvauxhall vectra safeguard messagevectra reset messagewhat does safeguard mean on vauxhall vectraopel vectra scritta safety guard come azzerarehow to check safeguard with multimeter
