Thread: oil leak !
Hybrid View
    redcar
    Default oil leak !
    hi all
    just bought my 2.2 sri from a local garage ( no warrenty) have just noticed there is an oil leak ( as u stand in fornt of car , too your left , bout 4 inches from the top of the engine looks like were oil is coming from) could some help me pinpiont were its coming from,buying this car has cleaned out all of me funds so any help would be greatful.
    thanks clembo
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Where about mate?
    redcar
    hi rushy sorry missed the all important bit its to the left side on your pic were the last pipe is just before the pic ends just under neath were a belt is if that any help.
    were the arrow is ita about three or four inches down in the engine
    Wales, UK
    Thats a familiar sight, had nightmares of this view trying to replace the HG myself!
    Wales, UK
    How about this one ?
    redcar
    hi were the two arrows are there is oil all over
    Regular Member RobW's Avatar
    Sep 2007
    Tain - Easter Ross
    Buying from a garage will cover you for 90 days warranty, even if they do not tell you or publicise it.
    Go back to them and ask them what they are going to do about it.
    Sticky point for them, if they are selling cars but not registered as a trader then they are in the wrong. If they are registered as a trader then by law they need to offer a warranty of some sorts, which is usually 90 days
    redcar
    hi robw the bloke in the garage said thats why they are cheaper as they do not offer warrenty on them dont know if they are registered or not. what you said is this concret proof that thay must offer some sort of warrenty.
    thanks clembo
    redcar
    @ mark_647 thanks for that i have looked in the service history june of last year (drive vauxhall ) recomended fitting a new timing chain but was not done so it could be part n parcel to what you have said , do you recon?
    thanks clembo
    Wales, UK
    Not sure, the first arrow on the left is where the cylinder head joins the engine block.
    However, I used to have a 2.2 - I once found the alternator, starter, tensioner and whole drivers side of the engine (Which is where your second, right side arrow is) covered in oil.
    The problem was the lower block timing chain cover seal and a leaking oil pressure switch on the front 'leftish' side of the engine. The pressure switch is very easily cured with a new one for around £19, a big spanner and a flexible arm! Although the timing chain cover is a lot more difficult. Nothing serious though !
    Hope this helps !
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
