Results 1 to 10 of 17
Thread: 2.2 direct failed mot on emissions,
    loughborough
    Default 2.2 direct failed mot on emissions,
    Hi, I have recently bought a 04 reg 2.2 direct vectra sri.
    I took it for MOT today and it failed on the emissions. It seems that the CO %vol is way to high
    (Max limit is 0.300)
    Mine is 6.036
    Also the emission light has come on. although i have noticed this on before then it went off.
    Has anyone eles had this problem or does anyone know what it could be
    Regular Member GAZWAH's Avatar
    darlington uk
    sounds like your catt is goosed,or lamba knackered....get them to plug it in and read it
    loughborough
    Ok, was kinda hopeing it would be something cheap and easy to sort.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Mine failed to.. but only at 0.428.. but was your engine warm? and had a good spin to clean it up.. probaly wont help to get it all the way down.
    Also besides the suggestions above, check for holes in the exchaust.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    seems there failing alot on the inlet manifold flaps problem ..get it tech tested and see what the codes are ......
    loughborough
    Unhappy
    Quote Originally Posted by benny View Post
    Would this be swirl flaps? as this is what it comes up with on a fault reader.
    It says swirl flap sticking , it has a fault code but i have forgoten it.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by clive3373 View Post
    Yes mate
    Regular Member Sambor's Avatar
    Elgin
    It comes on my VC the same fault.Two weeks ago i clean swirl flaps and now working better.But i'll see in May on MOT?
    Feb 2006
    dudley
    yep ....will need the new repair kit ......
    loughborough
    Would stuck swirl flaps make the co% high. Or could this be an unrelated fault?
    Thanks for your replys
  1. Failed MOT due to emissions
    By johnnylegs in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2011, 20:50
  2. Failed mot on emissions
    By G4GAV in forum The 'Off Topic' room
    Last Post: 9th March 2011, 21:21
  3. emissions values for 2.2 Direct
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 15:07
  4. emissions failed
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2009, 23:11
  5. Failed MOT on emissions
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 19:44
co emissions too high vectra c 2.2
