Thread: pre facelift vec c 2.2(z22se)problems
    Regular Member denzilbud's Avatar
    cambridge
    Default pre facelift vec c 2.2(z22se)problems
    i have just had a new downpipe and centre box fitted to my car,and ever since then its been running like a pig, poor fuel consuption,lacking power,poor idle ,ive cleaned the tb and blanked the egr all ready so its not them the car was running fine before exhaust was fitted,also i get the check safeguard and the car with spanner lights up then goes out,im going to buy position 1 and 2 lambdas and a coolant temp sensor and spark plugs could it be anything else any help would be great
    Regular Member old cruiser's Avatar
    slough
    To be honest mate I was gonna suggest lambda sensor as there is every possibilty it's been damaged, as they are pretty delicate things,have you had a visual at the sensor that sits on the top of the manifold , it's quite easy to see if you look at the back there, could even the cable going to it that's damaged.
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I'd look at the O2 sensors mate. Vid had the same problem on his 2.2 after getting a new downpipe and it turned out to be the O2. It first went in because there was a bit of weld in the o2 thread, then it went again and turned out the tip was damaged. Think there about £60 each.
    cambridge
    cheers guys lambda will be my first port of call also ive been out and had a look position 1 seems ok nothing visuallsy wront but position 2 has been bodged its been cross threaded and in at an angle
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by denzilbud View Post
    That's the one them mate, I believe #2 affects fueling and that's exactly what Vids looked like.
    cambridge
    cheers for the help might have to get another down pipe if its threaded
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Vids was made by a zorst place, the plug didn't seat properly because of the little bit of weld in the thread. To fix it they just drilled a new hole welded a new nut on for the plug to screw into and then just blanked the old broke hole, so no need for a new downpipe.
    cambridge
    i got it for next to nothing have a mate that works at eu
  1. 03 2.2 Sri problems (Z22SE)
    By Butler in forum Engine & Drivetrain
    Last Post: 18th January 2012, 23:57
  2. Z22SE engine - start problems
    By antchev in forum Engine & Drivetrain
    Last Post: 23rd September 2011, 10:45
  3. Few Problems z22se...
    By mutley in forum Engine & Drivetrain
    Last Post: 26th April 2011, 15:57
  4. Facelift HID Problems?
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2010, 20:01
  5. Z22SE engine problems
    By amd in forum Engine & Drivetrain
    Last Post: 14th February 2010, 16:09
