Results 1 to 10 of 13
Thread: Question about CDC40
    Regular Member johnny1983's Avatar
    Ryton, Gateshead
    Default Question about CDC40
    Am i right, that if the cdc40 and screen came from the same car that it is just plug and play? I have one to put in mine but now thinking it will need to be paired to my car?
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    As far as I know as long as the GID screen and CDC40 came from the same car them its just a simple plug into your car, as its the screen and head unit that are paired together. I could be wrong but sure try it out should be an easy job to do.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    as long as there paired together they will go in
    Irmscher Insignia CDTI 130
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Will working, no problem. However it is recommended to use Tech2 for put he correct Audio Index and Code index and Temperature Index for your car.
    CristianTM.
    Full Member Big Sig's Avatar
    Wouldn't they need to be divorced from the car and then married to the new one?
    Nov 2009
    Belfast
    no not for them to but maybe if you want trip computer to work
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Nope everything will work no need to divorce and marry again only problem you may have is DAB as i'm unsure how they connect to the car whether there coded or not ?
    You may need to do what Cristian said though
    Ryton, Gateshead
    Quote Originally Posted by bigmac View Post
    Will i just do that by going to the stealers? What would i ask them to do?
    Regular Member guitarbaz's Avatar
    Jan 2008
    A Geordie in Lincoln
    i'm told the dab box is coded as well.
    but tbh it's a bit of a minefield and information seems to conflict from one source to another. for example vx just told me that a divorced cdc40 and GID (not paired) couldn't be coded onto my car, an 09 plate. huh?!
    i'm awaiting further info....
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    If ALL parts are from the same donor car, then they will go straight in - no tech 2 required.
    The problem with the DAB unit is not programming, it is getting the correct looms and aerial links etc...as guitarbaz will testify!!
    Knowledge for programming equipment into Vx / Opel cars is quite limited within the dealer networks...
    You will find one or two nuggets of gold (willing and able dealers), but most have neither the time, knowledge nor wish to mess with changes from the original "factory" spec of the vehicle.
    My dealer in stockport south of Manchester told me that a CD70 from a Signum would not fit my Vectra!!! so what does that tell you!!
    I ended up travelling 30-odd miles to mid-point garage in northwich to have it done...took the boss man about 20 minutes to do all the long winded programming steps to set up the head-unit, screen and the BC / check control functions.
    It doesn't look easy to do...but this is by virtue of the amount of steps and menus and sub sections that have to be gone through to do what appears to be a little simple task.
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. cdc40 Aux in
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 00:03
  3. help with cdc40
    By deankenny in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2009, 15:23
  4. cdc40 question?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2009, 21:35
  5. CDC40 Question...
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 10:12
