Results 1 to 10 of 15
Thread: Passengers window switch
    Worcs/Staffs/Westmids (ish)
    Default Passengers window switch
    It's ****ing me off! help!
    Ok, it works fine until the missus gets in the car lol (typical)...
    It stops working properly and will only wind the window down (auto down only), not up again.
    It works from the drivers master switch with no problem at all, it also works again if you turn the ignition off/on.
    If I jump into the passenger seat I can't recreate the fault myself at all.......
    Is the daft moo doing something that confuses the switch or is something more sinister afoot?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    are you sure she's not winding you up??
    Regular Member PORKBALLS29's Avatar
    Epping
    Mine does exactly the same. If you take the switch appart carefully and spray some contact cleaner it will sort it. I think they're is a How 2 on this.
    Quote Originally Posted by lofty View Post
    Nah - it's an electric window mate...:
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Penfold101 View Post
    I knew I should have quoted the "winding"
    I did suspect that's where you'd gone with that one...
    Did you have any luck with the part numbers I gave you the other day...?
    @home
    Engine : 1.9 CDTi
    yes, Dan "quoted me happy" so much so I gave him a bigger list lol.
    I tell you - I'm paying for that guy's christmas bonus the amount of business I've given him...
    I'm still waitin on my parts though - on order from germany apparently...
    milton keynes
    IMHO it is better not to use contact cleaner and use a simple pencil eraser on the circuit board
    @home
    Engine : 1.9 CDTi
    looks like he'll be getting a bit from me too now. Thanks for pointing that one out.
    Sorry for the threadjack Birchy (keeps it at the top though).
  1. window switch
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2011, 15:01
  2. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  3. window switch
    By new2theroad in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2009, 12:58
