Thread: Park pilot
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Angry Park pilot
    Hi guys my parking sensors have stopped working and there is just a bell sound when I turn it on! Any ideas guys
    Usually means one of the sensors has become disconnected - quick inspection of front and rear with bumpers off should tell you...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Or maby if you put in the new roof loom you have disconnected some of the wires in the REC when plugging in the new loom?
    Jun 2009
    bradford
    Thanks guys-rec?.... Where is that ?
    milton keynes
    Rear Electrical Centre
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    This thread is repeated here.
    http://www.vectra-c.com/forum/showth...06#post1236706
    REC = fuse board on uk passenger side of the boot / load area
    (or drivers side of non uk vehicles)
    Jun 2009
    bradford
    right guys ...........following on from my park pilot not working, its the loom i have used for the interior bits that doesnt have the park pilot loom on it!!is it possible to run four wires from the park pilot loom into the rec or onto the new ribbon?..........thanks for all your help again
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    What connections are you missing to the REC there should be 5 in total 2 for speaker, 2 for Low Speed Can and a 12v feed?
    Jun 2009
    bradford
    hi mate.......the loom i have plugged in has two ribbons coming out of the plug, a thick one and a thinner one!! i assumed the thinner one for the park pilot but there is no plug on the loom to the speaker on the headlining!................then i have a totally separate plug - which i assume is for dimming mirror.
    can i run the wires from the old lead into the new loom,can you pull them out of the plug without breaking it? or simply just insert some wires and link them both together,
    as always help is appreciated, Andy
  1. park pilot
    By andy bo in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2013, 11:22
  2. Park Pilot
    By Simon_Fuller in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 11:17
  3. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  4. park pilot
    Last Post: 9th March 2011, 23:20
  5. park pilot
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:02
