Results 1 to 10 of 19
Thread: Undoing strut top nut
    West Midlands
    Default Undoing strut top nut
    So I've got the inevitable broken spring and have got the strut off the car, spring is safely under the control of the compressors and I'm trying to get the top nut off.
    I'm using the spark plug socket method with the allen key through the middle but the nut just will not move. So far I've broken a 1/4" extension bar, bent a spanner into a banana shape and twisted a 1/4" allen key into a spiral trying to hold the piston.
    Has anyone else had anything like this? Any ideas???
    Thanks in advance.
    Will
    Regular Member daviem-rfc's Avatar
    SUNNY DUMBARTON
    Just done my strut top bearing on saturday, that nut was a pain in the ass, though some wd40, metal grips, and strong socket set, a whack of the hammer and it was free
    Sunny Dartmoor
    I undone mine on the car before removing the strut not all the way just cracked it off so it was easier to undo when i removed them from the car,hth........
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    As glenboy said I used a 36inch breaker bar tocrack it off on the car
    Try putting the 3struttop bolts in on the car and try cracking it off
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    better to be loaded ie on the car and down on the deck if DIYing it..pop along to any garage they will crack it off with a buzz gun for you you say your using 1/4' stuff far to small and not capable 3/8 or 1/2'
    West Midlands
    Quote Originally Posted by Dose View Post
    Cheers - the 1/4" bar was just to go through the socket and hold the torx bit. I've given it a good soak with WD40 and will have another go tomorrow.
    R.I.P. 1/4" bar...
    scotland
    22mm socket with a bar welded to the side of it and a t50 torx bit through the middle of the socket to stop the shaft from turning. Thats how i done mine, a pain in the arse but it works.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I had this trouble on the Mrs' clio... If you cant get it off with muscles, the top allen key mount will start to round. I had a set of strange allen keys with a ball on the end? Anyway, a hammer helped get them in and they gripped fine when my Torx would not.. so that may help if you get stuck there.
    Unfortunately the only way I could get mine off was with a cutter lol. But.. even with the mount cut so I could pull it off i couldnt get the nut undone (for the bearings) no matter how much leverage and WD40 (or heat!) I used...
    Got in a rage and smacked the allen key with a Hammer.. and it just cracked off easy peasy! So probably best to shock it off.. but not an easy job when its on the car!!!
    Northampton, UK
    I put the allen key in to a table vice and un-did it that way
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Easiest way by far, a set of vortex sockets
    You'll find loads of uses for them after you've used them
  1. strut top
    By cj1175 in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2011, 14:34
  2. Strut top nut
    By kalim in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2010, 18:28
  3. Strut top question ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2010, 10:22
  4. Strut top
    By harny86 in forum Suspension, Wheels & Brakes
    Last Post: 29th December 2009, 19:02
  5. Strut Brace?
    By wotsthestory in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 17:40
vectra c strut top nut
undoing strut top nut
vectra c top mount nut
vauxhall insignia strut top mountings
