Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Cdti boost gauge
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Exclamation Cdti boost gauge
    Hi guys I need help asap I am fitting my boost gauge tomoro and on a tight budget so can't spend any more cash especially 20quid on a self sealing take off adaptor for the rubber boost pipe so my question is I have the t piece which I have sealed off the spare end with super glue and I was goin to put I tiny hole in the rubber boost pipe that goes into the inlet manifold on my 150cdti then push in tight the t piece and seal in with sealent will this be ok
    Or do I drill a small hole on the plastic boost pipe from te intercooler and push in the t piece and seal it there with glue I need help I can only do these 2 options so much apreciate a quick opinion I know it's not ideal but that's the way it is lol.
    If you can help asap thanks
    Norwich
    Trim : SXi
    Engine : 2.2
    It needs to be sealed or you will lose boost and could give you an error. In the past I have drilled and tapped the pipe and put a metal fitting in and used permabond or PTFE tape. Then fit 6mm silicone pipe (I use airline from work) which is a push fit into the fitting into the manifold. The feed it to the gauge.
    NEWCASTLE
    how much does all this kit cost?also does it do anything
    Norwich
    Trim : SXi
    Engine : 2.2
    Quote Originally Posted by harny86 View Post
    Boost gauge can be bought for anything from a fiver upto £30, most will come as a kit if not you need some tubing (Either airline or even the tubing you get on a fish tank for the air supply which will cost you about £1 a metre)
    Gauge just shows how much boost you are pulling thats it a nice little toy unless its a performance car then it is quite useful
    kings lynn, norfolk
    Hi guys fitted my boost gauge I used a 0.9mm welder tip I then drilled this out to 2.0mm I then drilled a 5mm hole on the plastic boost pipe just before the rubber one that goes into the manifold and screwed the welder tip in it was a very tight fit then sealed with loctite330 I fed the vacuum pipe through the steering linkage gaitor then up to the dash where my pod and gauge is mounted I used the ignition live feed the black wire from the light switch and earth was the bolt holding in the dash so it lights ip now with ignition on. I will take some pics and post up here soon all works good but the gauge does buzz loud when on boost how can i eliminate this
    I am getting 27psi spike and settles at about 24psi on max boost
    just the annoying buzz sound now could I cable tie the vacuum pipe to restrict it to stop the buzz
    NEWCASTLE
    wow i want one lol any one in north east no how to do this?
    caistor
    24psi???????? this seems high my mates 2 litre 240bhp petrol rover only runs 14psi
    do diesals run higher??
    kings lynn, norfolk
    Yeah diesels run alot biter my mates 300bhp cossie is running about 18psi peak
    it's very straight forward to do guys as long as you have the right tools it took me start to finish about 1hour and 30mins most time was spent drilling through the welding tip to get the 2mm hole for the take off from the boost pipe.
    If any one wants to know how do do this I will write up a step by step and can private message anyone with a cdti to tell them how or if you live close I can show you mine the gauge and pod holder with extra tube and some welding ops cost me all on all 26quid but I would advise getting a remote electrical gauge as the buzz is a bit annoying but working out how to cure this
    I will get a few pics tonite and post them up for you guys thank for all the advice
    kings lynn, norfolk
    pics as promised guys
    Norwich
    Trim : SXi
    Engine : 2.2
    Did you sort the buzzing?
  1. 1.9 cdti boost gauge how 2
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 18:33
  2. cdti boost gauge
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:20
  3. Boost gauge cdti 150 fitting.
    By Avin in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 16:20
  4. boost gauge 1.9 CDTi
    By CristianTM in forum Diesel Engine related
    Last Post: 10th October 2009, 22:56
  5. cdti boost gauge
    By davidjameswest in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2009, 00:17
how fit a boost gauge on a vectra diesel www.vectra-c.com
