Thread: vibration
    basildon
    Default vibration
    I have 1.9 diesel vectra 56 plate have got a vibration come through the peddles has any one had the same
    Regular Member DaveW555's Avatar
    Cannock
    which pedal in particular matey??
    basildon
    seems to be more on the clutch but travels through brake and throttle pedals
    Cannock
    If its the clutch it could be that either the DMF (dual mass flywheel) is on its way out or gone out of balance, or the release bearing/concentric slave is on its way out. Either would give you a vibration through the pedal. And in both cases its gearbox out to do the job and if I were you I'd do the lot while the box is out.
    WGAF#5
    as above DMF vibration /clutch plate wear
  1. vibration
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 11th April 2011, 07:32
  2. 2.2 sri vibration
    By lordreeson in forum Engine & Drivetrain
    Last Post: 27th October 2010, 19:44
  3. Vibration
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 20:46
  4. Vibration through car
    By Orbilator in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2008, 21:13
  5. vibration
    By Eddy R in forum Engine & Drivetrain
    Last Post: 20th August 2007, 19:59
