Thread: Installed Cruise Control not working
    Mar 2007
    Romania
    Default Installed Cruise Control not working
    Hello,
    I just installed cruise control on my car (2002 Vectra C 1.8 ZX18XE) and i did the following operations:
    1. Installed clutch switch
    2. Installed CC lever
    3. Activated CC in the Engine module with OP-COM
    4. Activated CC in the Instrument module with OP-COM
    Is there any operations left or i have to activate it with TECH 2 only.
    Please Help. Thanks!
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Tech2 !!! never use opcom to program
    You need to get tech2 and reset CIM and then program stalk's/Key afaik ,if you install a new stalk its the only way to get it to work
    Irmscher Insignia CDTI 130
    Regular Member darko2301's Avatar
    Croatia
    I also retrofitted CC, I had it activated via TECH2 and it works like a charm
    Mar 2007
    Romania
    Ok then i have to visit the local dealer and have the CIM reset, i will let you know if the problem was solved, thanks for the help.
    btw darko2301 nice vectra u got there
    Croatia
    lol cheers mate
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    is cc not standard. i have a 53 LS and I have it. infact ive never seen one without it
    West Yorkshire
    You have missed out a step, you need to do the coding in the CIM module as well as the engine and instruments. Go into the variant programming screen, change cruise control to "present" and country code to "great britain".
    You may also need to install a clutch switch if you don't already have one.
    If you have the proper op-com (called vaux-com in this country), there is no problem with using it to activate cruise. I have done this for lots of people with Astra H's/Zafira B's and it has worked every time.
    I personally wouldn't trust the op-com units bought on ebay. The real thing costs £700 for a reason (and is very good value compared to tech2). Have heard a few stories of weird results after doing programming with ebay op-coms and have had a bad experience myself with my old car, hence buying the genuine one.
    Mar 2007
    Romania
    There is no cruise control option in my CIM variant programming screen so i can't change it to present, strange... i admit, i don't have the £700 tool unfortunatelly... so should i go to the dealer tu use their Tech 2 tool?
    Mar 2007
    Romania
    Tere are lots of Vectra C cars without the CC installed, i have 2 friends here without it...
    in the UK it was only the entry level Expression model that didn't have it as standard, and that was discontinued as no-one bought it. It was fitted as the Vectra was mainly a motorway mile-munching company/hire car which would spend it's life doing 70...
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control not working :(
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 16:16
  3. Cruise control not working?
    By cjporter in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 16:10
  4. Cruise Control Not Working
    By dt100 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2009, 10:39
  5. Cruise Control not working
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 21:13
vectra c cruise control install
vauxhall vectra c cruise control not working
zafira cruise control not working
