Thread: Centre Display Not Switching Off With Ignition
    Regular Member DanR's Avatar
    Hampshire
    Vehicle : Insignia 2.0 CDTI Ecoflex
    Trim : Elite Nav
    Engine : A20DTH
    Default Centre Display Not Switching Off With Ignition
    Hi Guys,
    Just picked my car up from the garage and have noticed that the centre display stays switched on permanently (keys been out for about 30 minutes now and it's still on), radio & satnav screens disappear but I can still access the phone and BC screens.
    Before I phone the garage and moan at them is this normal beahviour or is there a setting somewhere that controls this?
    Dan
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by DanR View Post
    Hi Guys,
    Dan
    Have you tried disconnecting the battery for about 10mins sometimes this helps to reset things. hth
    Hampshire
    Trim : Elite Nav
    Engine : A20DTH
    Cheers, that sorted it!
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    No probs mate,glad to help.
    Hampshire
    Trim : Elite Nav
    Engine : A20DTH
    Default Centre Display Not Switching Off With Ignition - Update
    Hi Guys,
    Just thought I'd post an update on this;
    Two days after disconnecting the battery this issue returned, disconnecting the battery again had no effect. I figured as the display couldn't draw that much current it would be okay to leave over the weekend - how wrong I was!
    Battery managed to drain down to 4 volts and I had to get the recovery guys out for a jump start . Whipping the negative lead off until I used the car the following day solved that problem!
    However the issue appears to be related to the bluetooth problems that I have been having (module doesn't attempt to search for nearby devices) and the bluetooth unit has failed, holding the display on.
    According to the Dealer's Vauxhall tech new units are rare as rocking horse poo, however a quick call to my local Vauxhall dealer and I can have one in 48 hours so I am awaiting a new bluetooth module to be fitted, fingers crossed!
    Dan
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Screwed bluetooth module is causing it.... Unplug the bluetooth module and the rest of it will be ok.. Only answer is a new module I'm afraid.... (Once you've confirmed it is that).
    Seen in happen in another members car recently, new module cured it.
    Hampshire
    Trim : Elite Nav
    Engine : A20DTH
    Thanks Plasma,
    The module is indeed faulty and the dealer SHOULD have put one on order yesterday - after getting a price from Vauxhall I'm glad I'm not footing the bill though!
    Dan
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes, I have a basic Nokia CK7-W fitted to my CD70, and when there is a bluetooth connection....and a call in progress, or I am playing my mp3's through the phone, then it holds the display active.
    Once the call is ended, or the bluetooth is no longer active then the screen shut's off.
    Obviously the faulty unit in your case was convinced you were still in mid call and hence holding the display on.
  1. Centre display
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2012, 07:55
  2. advise on centre display
    By dcm23251981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2012, 09:22
  3. Help with centre display smd's
    By bopster in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2011, 22:24
  4. Radio comes on automatically when switching on ignition....
    By waterbourne in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 22:19
  5. centre display
    By vectra in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2007, 17:42
my display has gone off when engine off in my vectra c
