Thread: disc size on signum
    Regular Member cockney16v's Avatar
    stoke on trent
    Default disc size on signum
    i have a signum 19.cdti 2004
    does it have 285 mm disc on front or are the bigger
    are the backs 278mm
    285mm fronts, 278mm rears mate.
    Disc and pad kit numbers:
    285mm fronts - 93186297
    278mm rears - 93186300
    Should be about 60 quid each ish...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you have the 285mm discs on the fronts fella and the only difference on the rears is either solid or vented discs as they appear to be the same across the range
    The rears are either the 278mm solid discs on the lower engines, and 292mm vented discs on the 2.0 Turbo and all the V6's including the VXR's which are painted blue...
    Regular Member treadstone's Avatar
    Jun 2009
    Wood End, Atherstone
    Hi All
    I have a 55 plate Facelift (if that makes a difference) 150BHP - any chance you could let us know my sizes aswell? and whether I should go for vented on the fronts if they are not vented already?
    Cheers,
    tread
    All models have vented at the front mate - yours will be the same sizes as listed above (if it's a 1.9 CDTi 150)
    Jun 2009
    Yikes!!!
    My existing fronts are not vented....
    Cheers for the info
    Quote Originally Posted by treadstone View Post
    Yikes!!!
    Cheers for the info
    They should be mate - standard on all Vectra's...
    I think someone's screwed up somewhere...
    Jun 2009
    Seems to be some good deals on ebay for what I think is my replacements. Should I go for rear discs as well as fronts at the same time?
    While on the subject - I have heard some rubbing sounds from the front wheels after braking sharply on occasions and was wondering what it was?. What do think? or is it just my Elite's way of crying out for vents??
    Bought it from a dealer last summer - been a great car so far.
    Personally? If you're going to the trouble of getting the fronts changed and the right ones fitted, I'd spend the extra money now, get fronts and backs and then not have to worry about it for the next wee while. Give your local dealer a ring with the part numbers above for a quote, shouldn't be more than about 50/60 quid for each set plus fitment...
  1. Confused over front brake disc size Signum 2.0t
    By Envy in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2012, 16:40
  2. disc size
    By DIESEL150 in forum Handling & Braking
    Last Post: 11th January 2011, 22:37
  3. what size disc do i need
    By Grimo72 in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2010, 17:47
  4. signum 2.2 direct brake disc size
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 00:04
  5. disc size
    By wingers1982 in forum Handling & Braking
    Last Post: 14th February 2008, 23:57
