Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Wiring up a Snooper
    N E Somerset
    Default Wiring up a Snooper
    If I wanted to wire my Snooper up using the lead supplied (i.e. with just two bare wires at one end) instead of using the accessory socket connection lead e.g. running it down from the right side of the instrument binnacle where would I be able to (easily) connect the cable into?
    Mileage : 000
    Would it reach the accesory soket, maybe you could connect it to the back of that, or even the ignition switch, I am not sure what the colours of the wires you would need to conect to though, but it would only need to be live when the ignition is on, some one will put us right though.
    ignition switch is no good,as it is canbus
    either tap into ciggy socket or if you have the telephone pre wired socket behind the glove box
    if i was doing it, i'd wire it into the back of the ciggy lighter to get switched 12V.. the only other place that CANBUS may let you draw 12V without getting a fault light is from the glovebox bulb as i don't think that will flag a faultcode..I don't think you can draw 12V from the ignition switch like you used to be able to do, or the light switch, I think CANBUS was the end of that practice..How about behind the stereo?? BenH will be the man to ask as he fits all that kind of stuff for a living..drop him a pm
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You can take out the grill for the 7th speaker in the dash the run the wire behind the dash. I would tap into the cig lighter as I have done with my Parrot kit, but thats cos I dont know of another point
    If you're positioning it on the right hand side of the dashboard then the easiest place is from one of the wires going into the headlight switch. You'll find an ignition switched and a permanent live there.
    Just drop the wires down the side of the dash (pop off the A pillar trim for the easiest access) and you can drop the cable right down behind the headlight switch.
    You'll end up with a very neat install and practically no wires showing.
    i thought that you ran yours from the ciggy socket duncan
    Ashington, Northumberland
    You can take a feed straight off the back of the light switch loom. That is where I have my ignition feed for my satnav from. You can take the switch out as a whole unit by pushing the light switch in (it is under quite strong spring pressure) and turning clockwise whilst holding it in. The whole unit will then just come out of the dash. If you want any more I'll go out and do it with some piccies if you want.
    N E Somerset
    Pics would be great if it's not too much trouble (showing the detail of the wiring as well). Don't want to break anything.
    Push switch in
    Whilst holding in, turn to sidelight position
    Pull complete switch out
    Black wire is ignition feed (ignore red wire and scotchlock no. 2, that is for my satnav feed)
    I have a seperate earth to the bodywork for the satnav. You can do the same for your snooper. Hope that helps.
  1. snooper
    By chrosty in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2011, 22:58
  2. is there a snooper that????
    By dannyjpuk in forum General Chat
    Last Post: 21st April 2010, 19:26
  3. Snooper S1
    By bigmac in forum General items for sale
    Last Post: 8th May 2009, 16:08
  4. Anybody have a Snooper S2
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2007, 23:15
  5. Snooper S4
    By suj786 in forum General Chat
    Last Post: 12th December 2005, 11:19
vectra c side light wire colour
