Thread: Fault codes.. anyone help what they are?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Exclamation Fault codes.. anyone help what they are?
    Any chance you clever boys and girls can work out wtf these codes are!?
    B2524-04
    U2131-00
    B0975-00
    U2139-71
    U2201-00
    Thanks in advance
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    try looking them up on this list from the 'Troubleshooting' section. http://vectra-c.com/forum/showthread.php?t=19442
    best to do a search before posting questions, or youre likely to incur the wrath of many members
    oh well.. I tried..
    Quote Originally Posted by kentish_bloke View Post
    Oh believe me i did try using the search facility and failed, The codes i have are not all in there
    Regular Member DaveW555's Avatar
    Cannock
    2139-Engine Control Module (ECM)/Steering Column Function Control Module-Communication Error, Probable Cause-Steering Column Function Control Module.
    Thats the only one autodata 2009 will recognise, I'm afraid, Sorry matey hope that helps a little bit.
    Northampton, UK
    I think -
    B2524 License lamp circuit short to battery
    U2139 CAN-Bus No Communication with CIM
    U2201 CAN-Bus No Communication with EHU (Entertainment Head Unit)
    Sounds like your CIM might have died????
    corby
    Quote Originally Posted by blue estate View Post
    B2524-04
    U2131-00
    B0975-00
    U2139-71
    U2201-00
    Thanks in advance
    hi blue estate
    if you can post or message me your vin and i can put it straight into the laptop for a more accurate description also need to know what controllers the codes came from then i can tell you exactly what these codes are from opel tis 2000
    what scanner did you use for the codes as most cheap handhelds will only do engine codes
    andy
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
u2201-00
Vauxhall DTC U2201-00
can-bus no communication with ehu
Opel DTC averia U2201-00
can-bus no communication ehu opel astra
Opel DTC U2201-00
can bus no communication with ehu
u2201 fault code
fault code U2201
fallo u2139-71
u2201-00 can-bus no communication with ehu entertainment head unit
falt code u2201
U2201-00 Can-Bus No Communication with EHU
vectra c u2201-00
