Thread: Vec 2.2 Sri 04 missing?
    Shropshire
    Default Vec 2.2 Sri 04 missing?
    Hi Guys
    Just brought a vect 2.2 sri 04 petrol..
    When im acceleranting hard the car holds back and judders any ideas ?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Any warning lights on the dash? Does it rev up in neutral but under load holds back at about 3000rpm, and does it have 2 exhausts?
    Shropshire
    No warning lights yes revs fine in neutral. and yep gets to 3000rpm then starts arsein about.. yep it has the twin exhausts
    Vehicle : SRi
    Mileage : 137000
    It could be the HP fuel pump/reg, an expensive fix so if you've just bought it get it straight back and get them to sort it. Unfortunately its a common problem with the 2.2 direct to the point it was a feature on BBC's Watchdog. Although if its not too bad it could just be a coil pack.
    Shropshire
    will vx be able to tell me if its knackered ?.
    Vehicle : SRi
    Mileage : 137000
    Yep but they will charge you £50, but TBH its the best place to get it diagnosed. Did you buy it from VX?
    Shropshire
    Yep but they will charge you £50. Did you buy it from VX?
    That i did
    Regular Member Cam's Avatar
    Sep 2009
    Fife
    My mates 2.2 Direct has just been into the Stealers for a miss fire, Tech 2 said Coiul Pack, they changed that and it was still there, Tech 2 still said coilmpack, turned out to be the Fuel pump playing up
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ibrazier04 View Post
    That i did
    Straight back then mate and mention the fuel pump, they still to this day deny there's a fault buy as you just bought it you should be covered.
  1. What am I missing
    By webmonkey in forum Engine & Drivetrain
    Last Post: 18th July 2008, 22:47
  2. Missing - Please Help
    By LJ sxi-nav in forum Comedy & Humour
    Last Post: 7th July 2007, 14:41
  3. Is this why it's missing?
    By armstma1 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 11:56
  4. Is something missing?
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2007, 19:31
