Thread: Help!! Problem with front disc and pad contact.
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    Unhappy Help!! Problem with front disc and pad contact.
    Hi folks.... I replaced discs and pads all round about a thousand miles ago and have had an ongoing problem with the front nearside disc ever since.
    Basically the pad is not making full contact with about 3/4 of an inch of the visible disc face nearest the hub. It has a slight coating of rust whereas the rest is nice and polished by the pad.
    I did a little detective work by pushing the piston back into the caliper and noticed some side to side play on the caliper coming from the slides. Not much but I think it's a bit excessive. The pads are nice and free in the caliper and not jammed at all as is the piston (Or at least it seems so).
    Could this be enough to stop the caliper staying true when braking causing uneven contact with the pad and disc?
    Oct 2007
    When I said side to side play on the caliper slides I meant placing my hand on the top and 'rocking' the caliper inboard/outboard not sliding it if that makes sense.
    Oct 2007
    Wales, UK
    Cant offer any help but I can offer another thread bump !
    Oct 2007
    Thaks for looking Mark... here's another
    Oct 2007
    Oh well, guess I'll have to go it alone!!!
    Wales, UK
    Suprised theres no one who can help lol ! Another free bump !
    May 2008
    Tyneside
    I thought they should be bedded in by 1000 miles unless you are very light on the brake. Did you use a decent make of pad, very hard compound maybe? Are the pads perfectly flat? Are both sides of the disc affected? Try removing pad and rubbing it on a fine wet & dry on a flat surface to ensure it is perfectly flat.
    Oct 2007
    Thumbs up
    I have to say that they weren't the most expensive discs and pads on the market however they do appear perfectly flat. I'm not that light on the brakes and I have towed my caravan for 200 of the 1000 miles they have been on for. I might go for a strip down and sand as you say.. will have a look at the inner side of the disc tonight.
    I was thinking of swapping discs and pads over from the other side?
    Thanks for replying by the way tridley!!
    Oct 2007
    Just for info really if anyone's interested... I sussed the problem I have been having with uneven contact between discs and pads. It was a simple matter of relocating the retaining spring on the caliper as I think I hadn't replaced it correctly on reassembly!
  1. Front disc shields...
    By danBoy in forum Handling & Braking
    Last Post: 16th June 2010, 22:38
  2. CD70 NAVI language disc problem
    By peteopc in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2009, 14:20
  3. New front disc and pad replacement £??
    By pauls898 in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2009, 20:59
  4. Vectra Rear Disc Problem - Solution
    By kenyoncr in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2008, 01:56
  5. Help with my front disc brakes
    By dave.dave100 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 12:55
