Results 1 to 3 of 3
Thread: lambda confusion
    Ayrshire
    Default lambda confusion
    Been having problems with my car for some time now and had codes read and was showing up rear o2, priced up and would cost £120 for the lambda on the yh engine
    Code was p0136 02 sensor circuit malfunction (bank 1 sensor 2)
    The mechanic said the rear one should not effect the performance and cause the problems i am having (poor acceleration and bogging down @ 4500rpm)
    However i was on the phone to vauxhall today and the tech guy said it would as it is a comparison sensor on the yh engine....when it reads different or is inoporitive it will effect my fueling
    I AM CONFUSED..lol Internet says one thing and the tech guy says another
    Who's Correct, Really need to spend the money on the most important part first.
    After all this i decided to get an emmisions test and had some weird results
    Fast idle test
    co was 0.00% vol
    HC was 0.00% vol
    Lambda was slightly high @ 1.022 (reccomended values of 0.970 - 1.030)
    Would this indicate a lean engine?
    All this does not help now that i have a noisy timing chain aswell Starting to give up
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    slightly high lambda could be something as simple as an air leak in the exhaust drawing in more air.
    downstream o2 sensor can knock out the fuelling i had it on my dads corsa c
    price seems very hight though at £120 try your local motor factor and specify a NTK one there very good should be around £70 ive found them to be as good as OE and very reliable
    Ayrshire
    Quote Originally Posted by cerbrious View Post
    Thanks Cerbrious will try the local motor factors tomorrow
  1. SMD confusion
    By MattVecVXR in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:01
  2. DPF confusion.
    By JayF in forum Engine & Drivetrain
    Last Post: 7th April 2012, 10:00
  3. HID Confusion :(
    By antowns in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 19:11
  4. HID confusion
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 15:08
  5. air box confusion!!!
    By littlesxi in forum Diesel Engine related
    Last Post: 7th February 2008, 09:29
