Thread: 2.2 Dti limp mode
    Newcastle upon Tyne
    Default 2.2 Dti limp mode
    Hi,
    I have a 2.2 Dti 2003, owned it for a few years now and the other day I was coming up a slip road building up speed in 3rd i floored it and just before it hit 3000rpm there was a jolt and the car/spanner came on the dash and it went into safety get you home mode! i pulled over and turned engine off for a minute and all was fine!
    This did happen a few times when i first bought the car but I had it into VX for something else and they said the did a recall turbo calibration??!! (thought it was strange they were offering to do stuff for free! they also did my handbrake!) The car did pull much better after that and did not do the limp mode thing for 18 months!
    Any ideas please?
    Regular Member campbell's Avatar
    Jul 2009
    manchester
    helo i have same problem on computer p0234 engine overboost but urs could be something completely diffrent i had all vacume and sensors checked and it was fine they said mine could be turbo vanes sticking it could be something as little as a split hose get it put on tec computer see what codes are since putting red x in the diesel mine hardly ever does it try that first thats what the garage told me i didnt think it would work but its done something theres one called wyns or something its suposed to be better
    Newcastle upon Tyne
    Thanks, I will give it a try, I was thinkin that maybe the senors where cleaned by VX and thats why it has not happened in so long! i am not going to spend the money on it unless it does it regular.
    Have tried the how2 on reading codes without reader but would dos not work on mine!
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could be the small vacumm hoses you need to check them all very carefully for any splits also maybe worth taking the boost sensor out and giving it a clean.
    Sep 2010
    hamilton
    Quote Originally Posted by j88nya View Post
    Hi,
    Any ideas please?
    they go into limp mode usuallt cos there isnt enough air bein put into the engine,, vacum pipes, boost sensor, split turbo hoses, poss egr valve, rarely the handbrake switch causes the ecu to freak out, try vacum pipes first tho
    Regular Member Innes's Avatar
    Plymouth
    Definatly check the vacuum pipes. Its a pretty common fault on the 2.0 and 2.2dti's. If you decide the change them check out this thread I strated a while back. Easy to replace all pipes for £6.
    http://www.vectra-c.com/forum/showthread.php?t=115759
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
