Results 1 to 10 of 17
Thread: 2.2 petrol timing belt
    Nov 2007
    antrim
    Default 2.2 petrol timing belt
    Drove my car yesterday and parked up for the night with no apparent problems or noises. Went out this morning and car wouldnt start. I called the breakdown people and the guy has told me its the timing belt.
    I'm told this is very bad news. Could anyone tell me what is the best and worst case scenario here in terms of cost and an idea of what the costs might be in either case.
    Its a 2003 2.2LS petrol. Has 117k on the clock but had a f.sh. to last year.
    The car is only worth maybe 1500 quid so if its going to be massive money clearly it wont be worth it
    Cheers in advance
    Yes - the problem is your breakdown people. It's a timing chain for starters, not a belt...
    if it had gone on your last journey you'd have known about it. When you say it doesn't start, does it turn over and not start or simply not move at all...?
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    More than likely what has happened is when you've started it there has been no oil pressure in the tensioner so the chain has jumped a few teeth. Worst is a new head, con rods and pistons so effectively a right off and least is just a new chain kit at £130 for parts but expensive to fit.
    Nov 2007
    antrim
    Quote Originally Posted by Penfold101 View Post
    When I try to start it all I get is like a whirring noise. The breakdown guy said it was definitely a timing chain problem.
    Nov 2007
    telford,
    does it try to start( turn over) and just not fire into life.
    Regular Member GAZWAH's Avatar
    darlington uk
    is it the engine whiring or the starter motor???
    Nov 2007
    antrim
    Its just like a whirring - not the usual turning over. There is no clunking so
    it appears its not the starter motor.
    Had a mechanic out and he says its the timing chain. Says he will need to remove the head to check the pistons, valves etc and repair/replace
    whatever is needed along with a new timing belt etc.
    Says maybe £400 - £500, maybe more . Ah well not much I can do bar pay it.
    Regular Member DaveW555's Avatar
    Cannock
    If I were you I would get him to check the timing, set it to where it should be (if necessary), fit a new tensioner and then do a compression check on the engine before he takes the head off, could save you a good chunk as well.
    Nov 2009
    ilkeston
    hi there. new to site. am buying a 3ltr V6 diesel (56 reg) next week and wondered if anyone could tell me if it has timing belt or chain?
    cheers for any help
  1. timing belt help vectra petrol
    By Hodgy in forum North East RO Vacant - ARO - Vacant
    Last Post: 27th February 2013, 23:05
  2. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  3. 2003 Vectra C 1.8 Petrol Timing Belt Noise
    By chrisjt31 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:21
  4. Timing belt.. 1.8 petrol engine
    By waterbourne in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 21:05
  5. Timing Belt?
    By pocket in forum Engine & Drivetrain
    Last Post: 29th June 2010, 15:20
